rlaplant
Migrated Network Printers Showing in Registry but Not on Machine ... ?!?!
Weird .... So I read that there and was like ... that isn't going to work for us.
And I started testing intensively
<pattern type="Registry">HKCU\Printers\Connections\* [*]</pattern> is the part I worked on.
If I take those keys, and use USMT, to restore them. Then printers error.
However, if I backup those keys, and then restore them manually using regimport after the fact, no errors and the printers migrate.
  On 5/15/2014 at 8:01 PM, Peter van der Woude said:
I've never had a lot of success with printer migrations via USMT. If the printer already succesfully migrates, you still depend on a (network) location that contains the drivers.
Usually GPOs are quicker, or a manual to explain a user how to add a printer
In our environment .... there's no such thing as explaining to the user. So the keys, come over, and then I get driver errors because it tries to install all those printers at once. Adding the connection key's one at a time works great. But without the USMT mapping the HKCU keys don't know who to go to. Is there any way I can change where they "restore" to? I have a great programmer here, and if we could restore them to a junk key, he can read them and add them slowly (30 second pause)
NVM ..I think i found it.
  On 5/16/2014 at 7:49 PM, Peter van der Woude said:
Feel free to share your solution :)
Well .... once I can finally get the key to write somewhere that it can be read. I have a great programmer here that has a script ready for me to read the key via runonce, and add the printers slowly, probably one every 45 seconds. All at once crashes the driver installs. When I have it, Ill post it all.
