seag33k
Distribution Point Logs
What are the best logs to look at for determining problems with distribution points? We have 5 DPs. 2 of the DPs are failing to get distributed content. Both of these systems are remote sites so it could be due to network latency, but I need some logs to help narrow this down.
I am watching the distmgr.log. I see the following entry showing its retrying. The only other red messages are related to a DP that is currently offline at the moment. Two of my DPs updated successfully. The other two keep showing as Failed to distribute content.
Failed to process package BR100013 after 12 retries, will retry 88 more times SMS_DISTRIBUTION_MANAGER 5/14/2014 2:23:08 PM 2904 (0x0B58)
Thank You!
Usually it shows a bit above that line what it's trying to do and what it's failing on.
The DPs finally sync'd. I am not sure if if was due to network availabile bandwidth since I had it set to only use 20% of available bandwidth. Upped it to 35%.
