AmrelMahdy Posted May 21, 2014 Report post Posted May 21, 2014 All, I have a weird problem. I captured few days Ago Windows 8.1 Reference Computer and It had 3 Drives (C,D,E), When i deployed the Image using Stand Alone Media , I found that the sccm assigned Drive D to the USB Flash memory and the original Drives are shifted to E and F Drives. I tried to use TSvariable OSDPreserveDriveLetter and Set it to true but still same behaviour I has SCCM 2012 R2 in my Environment. any suggestions ? Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted May 21, 2014 Report post Posted May 21, 2014 stop using multiple drives in OSD, it's a bad idea and will always cause you issues, are you capturing images from virtual hardware or real computers ? i'd recommend using virtual.... Quote Share this post Link to post Share on other sites More sharing options...
AmrelMahdy Posted May 22, 2014 Report post Posted May 22, 2014 stop using multiple drives in OSD, it's a bad idea and will always cause you issues, are you capturing images from virtual hardware or real computers ? i'd recommend using virtual.... Thanks Nial, I was Capturing Physical Computer. And for More clarification , the image am Deploying Doesnt Make the Format and Partition Step as am Deploying this Image to install Windows 8.1 on C Drive and leave the rest of Drives as it is . Hint: When i used the same TS to Deploy Windows 7 on C Drive only , it worked fine as D,E Drives where the same and the Data Was Maintained, the problem only appeared When i deployed Windows 8.1 on C Drive Only Quote Share this post Link to post Share on other sites More sharing options...
Peter33 Posted May 22, 2014 Report post Posted May 22, 2014 Simple solution: just unplug the USB drive after you started the Task sequence. OSDPreserveDriveLetter only works for the OS drive. You could of course also add a script, which reassigns the drive letters for your data drives, at the end of your task sequence. Quote Share this post Link to post Share on other sites More sharing options...
