ThomasBNewcastle Posted May 23, 2014 Report post Posted May 23, 2014 Hello Thanks for reading my post I have been setting up a test SCCM 2012 R2 Environment - managed to get everything working :-) Apart from my Build and Capture I am running a V-Sphere environment, no issues to date I have made a "Build and Capture task Sequence" using the windows 7 CD When I boot the "test PC" I get the F12 for Network prompt Windows PE loads, I see the Password prompt and then I select my Task sequence Then the Task Sequence starts to run until 15% of "Applying Operating System" then I get an error message saying that the task sequence failed 0x80070002 Troubleshooting that I have done 1) looked at the SMSPXE log - all seems to be working fine 2) looked at the SMS log on the X: of my test computer (attached) - I cant find anything :-( 3) Made sure that my boot images, Windows installer and Operating system image are all on my DP with 100% 4) thinking that the issue was with my Operating image I have used another CD to import a different OS image - Same thing 5) I found the back up boot images on my hard drive so I have used them to - no change 6) made a new task sequance - same thing Since I cant see any error messages in the SMS.log file I am unsure on what to do next ( I cant see any error codes) but I am not sure what else to look for Anyone got any thoughts Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted May 24, 2014 Report post Posted May 24, 2014 sounds like a bad network connection, check for a valid ip when it fails, can you ping the fqdn of the management point ? also, we need the smsts.log file, it will be in x:\windows\temp\smstslog at this point. Quote Share this post Link to post Share on other sites More sharing options...
ThomasBNewcastle Posted May 24, 2014 Report post Posted May 24, 2014 HelloThanks for getting back to meI can ping the SCCMSERVER - I am getting a IP address from my DHCP I have attached my log file smstserror.log Quote Share this post Link to post Share on other sites More sharing options...
