khawkins
Past due - Will be installed
I’m having a bit of a problem with deployments in our US sites. Required applications are not installing they are downloaded but sit with this message in Software Center “past due will be installed”, but never install. You can however manually install them by clicking the install button. It only seems to affect newly built machines (all clients are Windows 7)
My Primary site is in the UK and I have a distribution point in the US. The UK site handles all of the Europe deployments and the DP in the US, all the US deployments.
I have tested this on a newly built laptop in the UK, it pulls down all the required applications and AV defs and installs them fine. However any new machines in the US, install the client and AV, but nothing else, also the version of the AV it installs is an old version. It only seems to be on new builds as any current workstations have been receiving app deployments.
Distribution groups and sites all look fine in Monitoring. Clients are getting the correct client settings, boundaries are in there. I’m all out of ideas, what am I missing?
