I have been running successfully capture images directly to my hard drive across the network then moving them up to the server after the fact. I am doing it this way to lessen traffic across the network and isolating the traffic to a single router so that it doesn't slow down the rest of the network. I then transfer the image up to the server after hours overnight so that the traffic is minimal during the work day. I have successfully done this several times. Now however when I try to capture an image using the same method I am getting a failure that seems to point to bad login to my local pc using my network credentials. I am going to attach the log generated by the failure and was wondering if I could get any helpful suggestions from the groupsmsts.log
