pej1025
USMT 4.0/Hard-links: Computers do not join domain
Hello! I'm trying to create a Windows 7 to Windows 7 computer refresh task sequence with USMT 4.0/Hard-links in SCCM 2012 SP1 CU1 environment. I followed Peter's tutorial http://www.petervanderwoude.nl/post/migrating-to-windows-8-by-using-hard-links-with-configmgr-2012/.
The task sequence I created based off of Peter's tutorial completes with no errors but the computer does not get joined to the domain. I'm using a service account that serves as a "domain join only" account specified in the Apply Network Settings step. I use this same account in several other of my OSD task sequences and the computers join the domain fine.
Is there a better way to do a computer refresh with same OS? I've only seen XP to 7 refresh scenarios around the web and I'm assuming it shouldn't matter with Windows 7 to Windows 7. If needed, I can attach any logs that would be helpful. Thanks!
