hhancock Posted July 6, 2014 Report post Posted July 6, 2014 Hello, I've recently uninstalled the Management Point role on my primary site (only site). After reinstalling the Management Point role, it appears that the MP is stuck in a critical state. Since the reinstallation, I only see two errors (as shown in my screenshot): Is there anyway to fix this? I've rebooted several times and haven't received these errors since but the MP remains "critical." Can I clear these events? I've tried resetting the count and refreshing the role but it still shows critical. All components have a status of OK. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted July 6, 2014 Report post Posted July 6, 2014 well have you tried to gollow the advice in the description of each of the Message ID's above ? Quote Share this post Link to post Share on other sites More sharing options...
hhancock Posted July 7, 2014 Report post Posted July 7, 2014 well have you tried to gollow the advice in the description of each of the Message ID's above ? Yes, as the Message ID's that are listed weren't really the problem. The real problem was that it couldn't contact the MP over HTTP. I've since resolved that issue by reissuing the web server certificate. Quote Share this post Link to post Share on other sites More sharing options...
AaronBISSELL Posted July 7, 2014 Report post Posted July 7, 2014 This is a known issue. Modifying the roles of an existing distribution point will reset the certificate settings of the distribution point. So - If you have a DP all set up and later decide to add / remove a role, you will need to reconfigure the certificate settings - import the cert. We broke this countless times before opening a ticket with Microsoft to have them tell us this. Quote Share this post Link to post Share on other sites More sharing options...
hhancock Posted July 7, 2014 Report post Posted July 7, 2014 This is a known issue. Modifying the roles of an existing distribution point will reset the certificate settings of the distribution point. So - If you have a DP all set up and later decide to add / remove a role, you will need to reconfigure the certificate settings - import the cert. We broke this countless times before opening a ticket with Microsoft to have them tell us this. Aaron, ours seemed to happen once we upgraded to R2. It's hard to pin down an exact time as we rarely use Configuration Manager and I don't really want to go that far back in the logs Regardless, the issue is resolved. Quote Share this post Link to post Share on other sites More sharing options...
