Jizz0
WinPE does not pick up IP to display task sequence
Ok. I have a boot image (WinPE_x86.wim) which I setup for OSD. Machine boots from PXE and PE starts to load. Then all of a sudden before any advertisements are shown, the machine loops and reboots. I have been able to determine the PE is not picking up an IP unless I run ipconfig /renew from command line. I have the correct network drivers so Im trying to figure out why the TS doesn't run unless I ipconfig /renew.
9 answers to this question
have you applied any network drivers to the boot.wim image ? the drivers must be Vista network drivers and you must update the distribution points after updating the wim file
Here is the full log:
<![LOG[LOGGING: Finalize process ID set to 876]LOG]!><time="19:32:11.734+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="tslogging.cpp:1489">
<![LOG[==============================[ TSBootShell.exe ]==============================]LOG]!><time="19:32:11.734+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="bootshell.cpp:963">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="19:32:11.734+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="util.cpp:869">
<![LOG[Debug shell is enabled]LOG]!><time="19:32:11.734+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="bootshell.cpp:974">
<![LOG[Waiting for PNP initialization...]LOG]!><time="19:32:11.750+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:59">
<![LOG[booted from network (PXE)]LOG]!><time="19:32:11.750+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="configpath.cpp:198">
<![LOG[Found config path X:\sms\data\]LOG]!><time="19:32:11.750+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:553">
<![LOG[booting from removable media, not restoring bootloaders on hard drive]LOG]!><time="19:32:11.750+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:564">
<![LOG[Executing command line: wpeinit.exe -winpe]LOG]!><time="19:32:11.750+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:767">
<![LOG[The command completed successfully.]LOG]!><time="19:32:24.558+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:850">
<![LOG[starting DNS client service.]LOG]!><time="19:32:24.558+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:597">
<![LOG[Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="19:32:25.088+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:767">
<![LOG[The command completed successfully.]LOG]!><time="19:32:25.088+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:850">
<![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="1" thread="964" file="tsmbootstrap.cpp:1038">
<![LOG[Command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="0" thread="964" file="tsmbootstrap.cpp:1039">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="1" thread="964" file="util.cpp:869">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\TSRESNLC.DLL']LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="1" thread="964" file="resourceutils.cpp:152">
<![LOG[PXE Boot with Root = X:\]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="1" thread="964" file="tsmbootstrap.cpp:920">
<![LOG[Executing from PXE in WinPE]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="0" thread="964" file="tsmbootstrap.cpp:935">
<![LOG[Loading TsPxe.dll from X:\sms\bin\x64\TsPxe.dll]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSMBootstrap" context="" type="0" thread="964" file="tsmbootstraputil.cpp:1319">
<![LOG[TsPxe.dll loaded]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tsmbootstraputil.cpp:1329">
<![LOG[Device has PXE booted]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tspxe.cpp:122">
<![LOG[Variable Path: \SMSTemp\2009.07.23.15.49.33.0005.{19199AAB-C684-4230-A0B6-C0C071B49108}.boot.var]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tspxe.cpp:134">
<![LOG[Variable Key Len: 61]LOG]!><time="19:32:25.104+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tspxe.cpp:141">
<![LOG[succesfully added firewall rule for Tftp]LOG]!><time="19:32:25.119+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="fwopen.cpp:123">
<![LOG[Executing: X:\sms\bin\x64\smstftp.exe -i 192.168.0.1 get \SMSTemp\2009.07.23.15.49.33.0005.{19199AAB-C684-4230-A0B6-C0C071B49108}.boot.var X:\sms\data\variables.dat]LOG]!><time="19:32:25.119+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tspxe.cpp:177">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="19:32:25.119+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="commandline.cpp:229">
<![LOG[set command line: "X:\sms\bin\x64\smstftp.exe" -i 192.168.0.1 get \SMSTemp\2009.07.23.15.49.33.0005.{19199AAB-C684-4230-A0B6-C0C071B49108}.boot.var X:\sms\data\variables.dat]LOG]!><time="19:32:25.119+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="commandline.cpp:707">
<![LOG[Executing command line: "X:\sms\bin\x64\smstftp.exe" -i 192.168.0.1 get \SMSTemp\2009.07.23.15.49.33.0005.{19199AAB-C684-4230-A0B6-C0C071B49108}.boot.var X:\sms\data\variables.dat]LOG]!><time="19:32:25.119+000" date="07-23-2009" component="TSPxe" context="" type="1" thread="964" file="commandline.cpp:805">
<![LOG[Executing command line: X:\WINDOWS\system32\cmd.exe /k]LOG]!><time="19:32:56.522+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="bootshell.cpp:767">
<![LOG[The command completed successfully.]LOG]!><time="19:32:56.522+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="bootshell.cpp:850">
<![LOG[successfully launched command shell.]LOG]!><time="19:32:56.522+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="880" file="bootshell.cpp:430">
<![LOG[Process completed with exit code 1]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="1" thread="964" file="commandline.cpp:1102">
<![LOG[succesfully removed firewall rule for Tftp]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="fwopen.cpp:146">
<![LOG[uExitCode == 0, HRESULT=80004005 (e:\nts_sms_fre\sms\server\pxe\tspxe\tspxe.cpp,185)]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tspxe.cpp:185">
<![LOG[Failed to download pxe variable file. Code(0x00000001)]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="3" thread="964" file="tspxe.cpp:185">
<![LOG[PxeGetPxeData failed with 0x80004005]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="3" thread="964" file="tsmbootstraputil.cpp:1419">
<![LOG[hrESULT_FROM_WIN32(dwError), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstraputil.cpp,1420)]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tsmbootstraputil.cpp:1420">
<![LOG[TSMBootstrapUtil::PxeGetPxeData(&bPxeBooted, sVariablesFile, sPxePasswd), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2217)]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tsmediawizardcontrol.cpp:2217">
<![LOG[oTSMediaWizardControl.Run( sMediaRoot, true, true ), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,936)]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tsmbootstrap.cpp:936">
<![LOG[Execute( eExecutionEnv, sConfigPath, sTSXMLFile, uBootCount, &uExitCode ), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1105)]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="0" thread="964" file="tsmbootstrap.cpp:1105">
<![LOG[Exiting with return code 0x80004005]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSPxe" context="" type="1" thread="964" file="tsmbootstrap.cpp:1117">
<![LOG[Execution complete.]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="bootshell.cpp:624">
<![LOG[Finalizing logging from process 876]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="tslogging.cpp:1736">
<![LOG[Finalizing logs to root of first available drive]LOG]!><time="19:33:12.185+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="tslogging.cpp:1578">
<![LOG[LOGGING: Setting log directory to "C:\SMSTSLog".]LOG]!><time="19:33:12.481+000" date="07-23-2009" component="TSBootShell" context="" type="1" thread="884" file="tslogging.cpp:1803">
here's the problem
if you can verify that DNS is working perfectly via nslookup
then.....I've seen this happening on Dell's and from google the recommended action i s to load the manufacturer's network drivers in the boot.wim and/or update the bios version to the latest
so can you try that ?
  anyweb said:
here's the problem
Any, thanks for your help in this. The issue has been resolved.
Resolution:
Jason Sandys (MS MVP) recommended that I confirm the network switch port was set to enable (STP) port fast... Once the change was made, everything worked fine again.
