KeithDib
System Center 2012 migration
Hi
I'm about half way through a 2007 to 2012 migration, its going OK and most objects migrated ok
I have a few machines in the site just for testing, I have set up a couple test applications and these deploy fine and install well
My issue is, Ive set up a new Windows 7 image, created a new BOOT wim etc, created a new TS for testing and deployed these to DP. The machine sees this TS in Software Center ok but when I try to run this I get an error
Unable to make changes to your system
None of the applications you tried ti install began
installation successfully. Investigate the reason for the
installation failures and then try to install the applications
again.
Click OK to return do Software Center
I have tried adding the WDS role and removing etc,
Can anyone help please
