WAZZIE
Package Conversion Manager 2.0.1 compatible with SCCM 2012 R2 CU1
Hi All,
Quick Question, perhaps you know the answer or have experience of installing pcm in a similar environment.
Does PCM 2.0.1 work on SCCM 2012 R2 CU1 ?
Why is PCM supported only one year from release ? Last release was feb 2013, so this means its now out of support from MS?
Simple questions, but i have not been able to find an authoritive answer from googleas yet !!
Thanks and regards,
Wazzie
Excellent News !
Thanks peter - great stuff as usual.
I will install in my dev env, then implement in live with more confidence now.
Regards,
WAZZIE
