edie209 Posted August 12, 2014 Report post Posted August 12, 2014 I have had SCCM2012 up and running great for about 2 years now. It is a VM running on Microsoft Hyper-V This summer I upgraded our Hyper V cluster and things went a little pear shaped I have everything back and working as it was, except SCCM. First of all the x86 boot disk was not available at my distribution point, I sorted this by deleting it and recreating and distributing it. However I am now getting an error at the applying OS stage of the task sequence the error is 0x8007000. With lots of reading I have been pointed to the Network Access Account, but no luck here I have tried a new account, and also a domain admin account and both fail, I have tried the "Allow clients to connect anonymously" in Distribution Point Properties with no luck. looking at smsts log files I see these errors RegQueryValueExW failed for Software\Microsoft\SMS\Task Sequence, SMSTSEndProgram TSManager 12/08/2014 10:20:03 1468 (0x05BC) GetTsRegValue() failed. 0x80070002. TSManager 12/08/2014 10:20:03 1468 (0x05BC) Error Task Sequence Manager failed to execute task sequence. Code 0x80004005 TSManager 12/08/2014 10:20:03 1468 (0x05BC) I have include the files hoping that someone can point me in the right direction smsts.logFetching info... smsts-1.logFetching info... Quote Share this post Link to post Share on other sites More sharing options...
edie209 Posted August 13, 2014 Report post Posted August 13, 2014 I think I may have made some progress. I figured that the issue was the OS installer that it was failing on so I removed it from my distribution point and then redistributed it and I have got further but failing on a driver package. My thoughts and I am not sure yet as I have to investigate further is that the cluster crash has caused some corruption to my distribution point. Is there a way I can remove everything that has been distributed and re distribute them or do I have to do every one individually? Quote Share this post Link to post Share on other sites More sharing options...
edie209 Posted August 13, 2014 Report post Posted August 13, 2014 I was reading this post http://www.windows-noob.com/forums/index.php?/topic/5686-problem-with-distribution-point-in-sccm2012/?p=22119 and I think that is what has happen to me there are references on the C:\ drive how I am not sure. So I need to get everything back to how it was. So I need some advice on the best way forward Quote Share this post Link to post Share on other sites More sharing options...
edie209 Posted August 18, 2014 Report post Posted August 18, 2014 I have fixed this issue and here is what I did. I think that when sccm came back online after the cluster upgrade it didn't see the D:\ drive and because of this referenced the c:\ drive because of this. First of all I was getting x86 boot disk was not available at my distribution point, I sorted this by deleting it and recreating and distributing it. But this was still looking at C:\ and when I came to the "applying OS stage" of the task sequence the error was 0x8007000. I went down the route of thinking it was a permission issue when it was actually unable to find the files. I realised that the references were all a bit messed up after quite alot of head scratching I read about creating blank txt file called NO_SMS_ON_DRIVE.SMS on the root of the drive on which you don't want any packages created so I did this and renamed the folders SMSSIG$ to SMSSIG$-old, SMSPKGSIG to SMSPKGSIG-old, SCCMContentLib to SCCMContentLib-old, SMSPKGC$ to SMSPKGC$-old, all of which had been created on the C:\ drive, and rebooted the server thinking all would now be ok. On reboot nothing worked again I was getting x86 boot disk was not available at my distribution point, I sorted this again by deleting it and recreating and distributing it. But no matter what I tried I could not get past the "applying OS stage" of the task sequence the error was still 0x8007000. Then it came to me in IIS my site was still looking to C:\ I changed this and now all is working again. I hope this might help someone else if you find yourself in a similar situation Quote Share this post Link to post Share on other sites More sharing options...
