taylormcc
duplicate guid in SCCM 2012 R2
Hi Scott and slyaii
THANK YOU VERY MUCH FOR YOUR SOLUTION
Could you please suggest how to avoid this Duplicate UUID assignment by SCCM going forward ? do we need to remove the config mgr client from the master VM template and install separately once the server built?
Each time the manual steps fix will be a time consuming. so how to avoid this issue in future.
Thanks & Regards,
Dhanabal M
