bloodjun
Cannot add packages/Operating System Images to SCCM 2012 R2
This issue arose a few days ago, and I have been struggling ever since. I captured two images from two separate machines. Then, I went through the normal steps of adding the OS's to SCCM. Steps I've done dozens of times. Everything is peachy. I then proceed to distribute the content. Seems to go alright until I get a dreaded red circle. Happens to both.
So, I check on the Content Status and it says: "Distribution Manager failed to access the source directory "sharepath."
I then check the path. Make sure SCCM (the server's name) has access to it. Everything seems to be perfect. Both the Share and NTFS permissions give SCCM full access.
When checking distmgr.log, I get the following:
Successfully created RDC signatures for package ATY00088 version 2 SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
\ATY00088.2 could not be located SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
Failed to get RDC signature path for package ATY00088 version 2. Error = 2 SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
SnapshotPackage() failed. Error = 0x80004005 SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
STATMSG: ID=2361 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=sccm.assurity.local SITE=ATY PID=2200 TID=8836 GMTDATE=Mon Aug 18 21:17:34.238 2014 ISTR0="\\sccm\c$\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Windows Preinstallation Environment\amd64\en-us\winpe.ATY00088.wim" ISTR1="WinPE 8.1 x64" ISTR2="ATY00088" ISTR3="30" ISTR4="99" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=400 AVAL0="ATY00088" SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
CDistributionSrcSQL::UpdateAvailableVersion PackageID=ATY00088, Version=2, Status=2302 SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
STATMSG: ID=2302 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=sccm.assurity.local SITE=ATY PID=2200 TID=8836 GMTDATE=Mon Aug 18 21:17:34.262 2014 ISTR0="WinPE 8.1 x64" ISTR1="ATY00088" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=400 AVAL0="ATY00088" SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
Failed to process package ATY00088 after 1 retries, will retry 99 more times SMS_DISTRIBUTION_MANAGER 8/18/2014 4:17:34 PM 8836 (0x2284)
TL;DR - Failed to get RDC signature path for package. SnapshotPackage() failed. Error = 0x80004005.
I updated certain pieces of content on my Distribution Point (images that used to work) and they will no longer update (red circle.)
What did I DO!? SCCM is completely broken for me, and that is not acceptable. Been working on this for 9+ hours today and all out of ideas.
If you need any more information, please don't hesitate to ask.
Thanks.
