Having issues installing software on machines through non admin accounts. The user can request it through the catalog but then it sits on downloading 0%.
Have checked the logs and am getting these errors:
Successfully sent location services HTTP failure message. DataTransferService 9/3/2014 10:00:29 AM 5196 (0x144C)
Error sending DAV request. HTTP code 404, status 'Not Found' DataTransferService 9/3/2014 10:00:29 AM 5196 (0x144C)
GetDirectoryList_HTTP failed with code 0x87d0027e. DataTransferService 9/3/2014 10:00:29 AM 5196 (0x144C)
Non-recoverable error retrieving manifest (0x87d0027e). DataTransferService 9/3/2014 10:00:29 AM 5196 (0x144C)
Have checked webdav and was missing the permissions from here:
http://gabrielbeaver.me/2012/08/sccm-2012-part-i-pre-configuration/
Have added them in but am still having issues. Works under admin accounts but not under any other user.
Well it seems, having given it a few days it now seems to be working?! All i've done is added those permissions which is weird cos as you say (and having since read around) you dont need anymore. I'll give it a test over the coming days and if the issue returns will repost. Thanks for the help though, much appreciated
