ucho Posted September 18, 2014 Report post Posted September 18, 2014 Hey All IT guys, I have a problem with setting up the lab enviroment - I have 2 VM's running WinSRV 2008 R2 One is DC and second is running SQL server 2008 SP3 with CU 16 - version 10.0.5852.0 I getting below error while trying to install SCCM 2012 - Also logs shows this: 9/18/2014 9:47:55 AM: ConfigMgrSetupWizard Information: 1 : Cannot detect SMS Type because either SiteServer, SqlServer or SiteServerName is empty.9/18/2014 9:53:29 AM: ConfigMgrSetupWizard Information: 1 : Creating SQL connection to database master on server CAS.ACME.net.9/18/2014 9:53:30 AM: ConfigMgrSetupWizard Information: 1 : Sql connection is established. Can you please advise what to do? Quote Share this post Link to post Share on other sites More sharing options...
ucho Posted September 18, 2014 Report post Posted September 18, 2014 Error Code: Configuration manager requires MS SQL 2008 SP 2 with CU 9 or higher, MS SQL 2008 SP3 with CU 4, MS SQL 2008 R2 SP1 with CU 6 or MS SQL 2012 with CU 2 or higher. You must upgrade SQL server before installing SCCM Quote Share this post Link to post Share on other sites More sharing options...
