zaid Posted September 19, 2014 Report post Posted September 19, 2014 Hello, After installing reporting point on a second server, I am able to view the reports, but there's no link under "Report Manager" as well as the "ReportServer" link shows a plain-text page instead of the regular SSRS page. Any ideas? Thank you. Quote Share this post Link to post Share on other sites More sharing options...
GarthMJ Posted September 21, 2014 Report post Posted September 21, 2014 By the looks of it, You have setup or reporting site incorrectly. Reportserver is a valid URL or the management of SSRS, however you should be using reports for access to the actual reports. Review how to setup SSRS, if both ReportServer and Reports url work then check your Reporting port configuration. Quote Share this post Link to post Share on other sites More sharing options...
zaid Posted September 25, 2014 Report post Posted September 25, 2014 I ended up re-installing SSRS and it fixed the issue. Thanks! Quote Share this post Link to post Share on other sites More sharing options...
