Joe Posted September 19, 2014 Report post Posted September 19, 2014 Nevermind; it really was a stupid mistake that cost me half a day. Quote Share this post Link to post Share on other sites More sharing options...
0 GarthMJ Posted September 21, 2014 Report post Posted September 21, 2014 On 9/19/2014 at 9:52 PM, Joe said: Nevermind; it really was a stupid mistake that cost me half a day. For other that might find this post, it might be helpful to give them an idea as to what happens so that they don't do the same mistake as you. Quote Share this post Link to post Share on other sites More sharing options...
0 Joe Posted September 22, 2014 Report post Posted September 22, 2014 Sure. When dealing with configuration baselines and registry settings -- When you are creating an Execution Policy that looks at registry keys in HKLM\Software, make sure you tick the box for "This registry value is associated with a 64-bit application" if you don't want the rule to look in HKLM\Software\wow6432node. I was setting a windows setting, which wasn't really associated with a 32bit or 64bit "application". I passed by this setting without really thinking about it. I ended up creating a really weird text string that I could search for and found it under the wow6432node key. A lesson I won't forget! Quote Share this post Link to post Share on other sites More sharing options...
