kinanhaffar
Can't deploy any applications through SCCM 2012 R2, Management Point Critical Error
Hi all;
I have the following critical situation:
1. With in the Site Status the Site System Role "Management Point" status is Critical. If I start the Configuration Manager Service Manager and query the SMS_MP_Control_Manager, it shows that it is stopped, when I start it, i get the above error immediately in the event log.
Event Log error:
component SMS_MP_CONTROL_MANAGER on computer SCCM-PRI.domain.com reported: SMS Executive detected that this component stopped unexpectedly.
Possible cause: The component is experiencing a severe problem that caused it to stop unexpectedly.
Solution: Refer to your ConfigMgr Documentation or the Microsoft Knowledge Base for further troubleshooting information.
2. On Client machines, I see lots of event 6006 warnings, Source: Wlclntfy
The winlogon notification subscriber <Profiles> took 129 second(s) to handle the notification event (Logon).
And:
Event ID: 63, source: WinMgmt
The description for Event ID ( 63 ) in Source ( WinMgmt ) could not be found. It contains the following insertion string(s): PolicyAgentInstanceProvider, root\CCM\Policy\S_1_1_0.
And:
The description for Event ID ( 63 ) in Source ( WinMgmt ) could not be found. It contains the following insertion string(s): PolicyAgentInstanceProvider, root\ccm\Policy\Machine.
And:
The description for Event ID ( 63 ) in Source ( WinMgmt ) could not be found. It contains the following insertion string(s): PWRInvProvider, root\cimv2\SMS.
And:
The description for Event ID ( 63 ) in Source ( WinMgmt ) could not be found. It contains the following insertion string(s): AMTProvisionProvider, root\CCM.
On the Primary Site server I've noticed the following errors:
1. CcmMessaging.log
No reply message from Server. Server may be temporarily down or a transient network error.
Post to http://BBK-SCCM-PRI.bbk2310.com/ccm_system_windowsauth/request failed with 0x8000000a.
2. ClientIDManagerStartup.log
RegTask: Failed to send registration request message. Error: 0x8000000a
RegTask: Failed to send registration request. Error: 0x8000000a
3. MP_GetSdmPackage.log
Failed to initialize handler
Failed to process request(0x80070005).
4. LocationServices.log
Failed to send management point list Location Request Message to BBK-SCCM-PRI.bbk2310.com
5. SrcUpdateMgr.log
Instance of CCM_SourceUpdateClientConfig doesn't exist in WMI
6. ccmperf.log
Failed to create or open file mapping for CcmFrameworkServer\CcmIsapi
PerfObject::InitMemoryMap failed (80070005)
Failed to initialize memory map for CcmFrameworkServer\CcmIsapi
7. PolicyAgentProvider-20140922-100458.log
[0000000001CEFB38] Failed to cancel internal event sink query (80010108)
8. StatusAgent-2014922-032908.log
Successfully sent location services on HTTP failure switching to success message for MP 'BBK-SCCM-PRI.bbk2310.com'.
9. CcmEval.log
Result: Not Applicable, ResultCode: 0, ResultType: 0, ResultDetail:
Failed to get SOFTWARE\Policies\Microsoft\Microsoft Antimalware\Real-Time Protection\DisableIntrusionPreventionSystem
Successfully sent location services HTTP failure message.
Can't get MP list from MP
MP check failed for 6 times and exceeded the threshold 3
I have 3 SCCM servers, CAS, Primary and Secondary, the issue is taking place on the Primary server.
The CAS and the Primary servers are on the same subnet. The Secondary server is on another subnet.
Nothing have lately changed.
Please help me.
Thanks.
your problems are all related to the fact that your management point is down, have you reviewed any of the logs related to the management point to see why it's failing ?
Thank you for your reply, please find below additional MP logs:
Here are the logs:
1. MPcontrol.log
SMS_MP_CONTROL_MANAGER received START notification.
MPStart(): Registered for Notifications.
CMPControlManager::ReadConfigurationSettings(): m_pWmi->GetObject() failed - 0x80041010
CMPControlManager::ReadConfigurationSettings(): Periodic Interval is 1800000
CMPControlManager::ReadConfigurationSettings(): WINS Interval is 14400000
MPStart(): ReadConfigurationSettings() returned 0x80041010.
Querying MPHealthCheckIntervalInSeconds registry value returned a status of 2.
Querying MPHealthCheckTimeoutInSeconds registry value returned a status of 2.
Querying MPHealthCheckStatusMessageIntervalInSeconds registry value returned a status of 2.
Querying NLBNodeAvailabilityState registry value returned a status of 2.
MPStart(): Read all MP Settings.
MPStart(): SSL disabled.
CMPControlManager::WriteToCCMSettings(): WMI Connection established.
CMPControlManager::WriteToCCMSettings(): pWmi->GetObject() failed - 0x80041002
STATMSG: ID=5432 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_MP_CONTROL_MANAGER" SYS=BBK-SCCM-PRI.bbk2310.com SITE=PRI PID=9016 TID=6664 GMTDATE=Tue Sep 23 02:01:35.325 2014 ISTR0="" ISTR1="" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=0
MPStart(): WriteToCCMSettings() failed - 0x80041002
SMS_MP_CONTROL_MANAGER failed to start with 0x80041002
2. MPFDM.log
Verifying local MP outbox directory D:\Program Files\Microsoft Configuration Manager\MP\OUTBOXES\bgb.box for Notification Manager exists...
Verifying local MP outbox directory D:\Program Files\Microsoft Configuration Manager\MP\OUTBOXES\ddr.box for Discovery Data Manager (Trusted) exists...
MP Manager outbox Notification Manager maps to D:\Program Files\Microsoft Configuration Manager\inboxes\bgb.box
Worker thread [Notification Manager] halting execution.
MP Manager outbox Discovery Data Manager (Trusted) maps to D:\Program Files\Microsoft Configuration Manager\inboxes\auth\ddm.box
Worker thread [Discovery Data Manager (Trusted)] halting execution.
Verifying local MP outbox directory D:\Program Files\Microsoft Configuration Manager\MP\OUTBOXES\swm.box for Software Metering Processor Usage (Site) exists...
Verifying local MP outbox directory D:\Program Files\Microsoft Configuration Manager\MP\OUTBOXES\polreq.box for Successful Policy Requests exists...
Verifying local MP outbox directory D:\Program Files\Microsoft Configuration Manager\MP\OUTBOXES\stat.box for Status Manager exists...
MP Manager outbox Software Metering Processor Usage (Site) maps to D:\Program Files\Microsoft Configuration Manager\inboxes\swmproc.box\usage
Worker thread [software Metering Processor Usage (Site)] halting execution.
MP Manager outbox Successful Policy Requests maps to D:\Program Files\Microsoft Configuration Manager\inboxes\polreq.box
Worker thread [successful Policy Requests] halting execution.
Successfully reset permission of inbox D:\Program Files\Microsoft Configuration Manager\inboxes\statmgr.box\statmsgs
MP Manager outbox Status Manager maps to D:\Program Files\Microsoft Configuration Manager\inboxes\statmgr.box\statmsgs
Worker thread [status Manager] halting execution.
Please advise.
