firstcom
Content is not fully distributing to 2nd DP
OK, so directly after that, the next line should be "successfully distributed content", as there are a couple of SCCM Client packages that are automatically distributed every time you build a distribution point. If those initial/automatic packages didn't transfer, then future packages/apps that you've been sending will also fail.
When you built the DP, did you first install IIS on the Windows 2012 server? As you're creating a new DP, in the dialogue options, there is a checkmark for "Install and configure IIS if required by Configuration Manager." Did you check that box?
This DP was created on 8/13. There are SOME packages that have been distributed successfully, but not all of them. This shows that the connection works.
On 8/17 we re-configured the DP. There's a line that states that IIS was successfully configured. Some content was distributed but then it stopped taking content again.
Hi There,
I had this exact same error, I realised that the secondary server was not in the security group i have with full admin permissions to each site server and the OU in Aactive Directory but i think it also could have been the site server installation had not completed properly. Once i had the right permissions set up i did the following:
Remove distro point role from secondary server
Re-install IIS pre-requisite features
Run a recovery on the secondary site
Once the recovery successfully completed i installed the distro point role and it all worked :)
