Judical Posted October 1, 2014 Report post Posted October 1, 2014 Hello, When you Pre Provision Bitlocker does it bind to a computer name at this time or does it wait until Bitlocker is enabled? The issue I'm having is that Bitlocker is using the computername MINIT-***** instead of the name that I am changing it to after the OS is installed. I have the pre provision before the OS install and enable Bitlocker at the end of the TS. This is causing me to decrypt and encrypt to get bitlocker to show the correct computer name. Please let me know if the Pre Provision is causing this. -Judical Quote Share this post Link to post Share on other sites More sharing options...
Judical Posted October 3, 2014 Report post Posted October 3, 2014 After doing some research I have found that there is no way to fix this. Just have to remove the pre-provisioning from the TS and wait for bitlocker to encrypt the drive. Quote Share this post Link to post Share on other sites More sharing options...
BB24 Posted October 8, 2014 Report post Posted October 8, 2014 Correct, this only works 'properly' with Windows 8. If you don't care about the MININT-xxxxxx name in the PIN screen pre-provision works and speeds the build time significantly. Quote Share this post Link to post Share on other sites More sharing options...
