pfors
Removing a Site System from the Console that is Offline
We have a server that has broken down and is unable to start.
What is the way to remove the site system from the System Center 2012 Console, if the server is offline?
In SCCM 2007 you had to remove all the packages before you could delete a role. Which was a problem when the server was unreachable.
What’s the situation i CM12?
best regards Pernilla
