The problem I have is after the task sequence installs the OS and drivers it reboot to windows 7, once it reboots the USB ethernet is no longer installed so the task sequence fails.
I'm using a Dell fm76n usb ethernet device for the network and I've create a driver package to install the driver that came with the device however it still will not build please help
Hi All,
I'm having an issue with OSD on the XPS 13 9333. I can PXE boot the device and install the OS I also applied all the drivers from the driver CAB on the DELL website (http://en.community.dell.com/techcenter/enterprise-client/w/wiki/2065).
