hadi
sup and dp in the same box take up double disk space
I 've got system center configuration manage installed and Software update point and distrbution point are in the same server . after getting Updates from Microsoft and deploying them I understood that it's coping Updates into Distribution point content library.that's ok.But It is using double disk space . Is there any way to distribute Updates without coping them into Distribution point?and using less disk space? thanx
