Unique01
Move package to another distribution point
Hi all,
I have 2 distribution points, and one package being distributed to all clients, by a single one. For organization purposes, i need to move the package already existing in the original DP to the other. What's the best way to achieve this? Add the second DP, update distribution points, and after content is available, remove the original one? Or simply delete the original package, and create a new one assigning to the Dp i want?
Any suggestions would be much appreciated.
Cheers,
Powershell saving your time if you wont use console it will take long time and posible made lots manual error.
you can start with this:
Here is eksample how you can start:
# Define output file
$script_parent = Split-Path -Parent $MyInvocation.MyCommand.Definition
$csv_path = $script_parent + "\Update_Package_SrcPath_input.txt"
# Define data source path to search for
$OldPath1 = "\\LABSCCM01\Sources\Packages"
# Search and export packages
Get-CMPackage | Select-object Name, PkgSourcePath, PackageID | Where-Object {$_.PkgSourcePath.ToLower().contains($OldPath1.ToLower())} | Export-Csv $csv_path -Encoding Unicode -NoTypeInformation -delimiter "`t"
kind regard
sg
http://www.learnmesccm.com/
https://www.linkedin...ahic/a0/842/b21
