alex87
Deployment Issue
Recently we have been having problems deploying any image to client machines.
Initially our SCCM server stopped responding to all PXE requests but after numerous re-installs of components, client machines can now PXE boot into the PE client.
Now we are having an issue once the client boots into PE.
Once the PE starts loading it reboots before it gets to the task sequence.
The smsts log contains the following error:
[<![LOG[Exiting with return code 0x80004005]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmbootstrap.cpp:1117">
<![LOG[Execution complete.]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:624">
<![LOG[Finalizing logging from process 816]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="tslogging.cpp:1736">
<![LOG[Finalizing logs to root of first available drive]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="tslogging.cpp:1578">
<![LOG[LOGGING: Setting log directory to "D:\SMSTSLog".]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="tslogging.cpp:1803">
Googling the error code suggests a PXE certificate error, I've regenerated the PXE certificate and restarted the WDS service but still receive the same error.
I have also tried the following to no avail:
Created a new boot image
Re-imported the XP OS
Created a new task sequence and advertised to a new collection
Rebooted the server
Has anyone experienced a similar problem before?
Thank you.
7 answers to this question
Apologies for the late reply.
PE crashes out 2 different points randomly.
These are either:
"Windows is starting"
or
"Preparing Network Connections"
Below is the smts.log in full:
<![LOG[LOGGING: Finalize process ID set to 816]LOG]!><time="10:19:15.515+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="tslogging.cpp:1489">
<![LOG[==============================[ TSBootShell.exe ]==============================]LOG]!><time="10:19:15.515+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="bootshell.cpp:963">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL']LOG]!><time="10:19:15.515+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="util.cpp:869">
<![LOG[Debug shell is enabled]LOG]!><time="10:19:15.515+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="bootshell.cpp:974">
<![LOG[Waiting for PNP initialization...]LOG]!><time="10:19:15.625+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:59">
<![LOG[booted from network (PXE)]LOG]!><time="10:19:20.359+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="configpath.cpp:198">
<![LOG[Found config path X:\sms\data\]LOG]!><time="10:19:20.359+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:553">
<![LOG[booting from removable media, not restoring bootloaders on hard drive]LOG]!><time="10:19:20.375+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:564">
<![LOG[Executing command line: wpeinit.exe -winpe]LOG]!><time="10:19:20.859+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:767">
<![LOG[Executing command line: X:\WINDOWS\system32\cmd.exe /k]LOG]!><time="10:19:21.125+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="bootshell.cpp:767">
<![LOG[The command completed successfully.]LOG]!><time="10:19:21.125+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="bootshell.cpp:850">
<![LOG[successfully launched command shell.]LOG]!><time="10:19:21.125+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="820" file="bootshell.cpp:430">
<![LOG[The command completed successfully.]LOG]!><time="10:19:34.015+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:850">
<![LOG[starting DNS client service.]LOG]!><time="10:19:34.015+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:597">
<![LOG[Executing command line: X:\sms\bin\i386\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="10:19:34.531+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:767">
<![LOG[The command completed successfully.]LOG]!><time="10:19:34.531+000" date="08-18-2009" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:850">
<![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="10:19:34.578+000" date="08-18-2009" component="TSMBootstrap" context="" type="1" thread="1344" file="tsmbootstrap.cpp:1038">
<![LOG[Command line: X:\sms\bin\i386\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="10:19:34.578+000" date="08-18-2009" component="TSMBootstrap" context="" type="0" thread="1344" file="tsmbootstrap.cpp:1039">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL']LOG]!><time="10:19:34.578+000" date="08-18-2009" component="TSMBootstrap" context="" type="1" thread="1344" file="util.cpp:869">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\i386\TSRESNLC.DLL']LOG]!><time="10:19:34.578+000" date="08-18-2009" component="TSMBootstrap" context="" type="1" thread="1344" file="resourceutils.cpp:152">
<![LOG[Processor Is IA64: 0]LOG]!><time="10:19:34.593+000" date="08-18-2009" component="TSMBootstrap" context="" type="1" thread="1344" file="tsmbootstrap.cpp:1004">
<![LOG[PXE Boot with Root = X:\]LOG]!><time="10:19:34.593+000" date="08-18-2009" component="TSMBootstrap" context="" type="1" thread="1344" file="tsmbootstrap.cpp:920">
<![LOG[Executing from PXE in WinPE]LOG]!><time="10:19:34.593+000" date="08-18-2009" component="TSMBootstrap" context="" type="0" thread="1344" file="tsmbootstrap.cpp:935">
<![LOG[Loading TsPxe.dll from X:\sms\bin\i386\TsPxe.dll]LOG]!><time="10:19:34.593+000" date="08-18-2009" component="TSMBootstrap" context="" type="0" thread="1344" file="tsmbootstraputil.cpp:1319">
<![LOG[TsPxe.dll loaded]LOG]!><time="10:19:34.609+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmbootstraputil.cpp:1329">
<![LOG[Device has PXE booted]LOG]!><time="10:19:34.609+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tspxe.cpp:122">
<![LOG[Variable Path: \SMSTemp\2009.08.18.10.08.04.0003.{A97578A4-6C34-445A-9213-D6B5124EB707}.boot.var]LOG]!><time="10:19:34.609+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tspxe.cpp:134">
<![LOG[Variable Key Len: 61]LOG]!><time="10:19:34.609+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tspxe.cpp:141">
<![LOG[succesfully added firewall rule for Tftp]LOG]!><time="10:19:34.640+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="fwopen.cpp:123">
<![LOG[Executing: X:\sms\bin\i386\smstftp.exe -i 172.16.1.16 get \SMSTemp\2009.08.18.10.08.04.0003.{A97578A4-6C34-445A-9213-D6B5124EB707}.boot.var X:\sms\data\variables.dat]LOG]!><time="10:19:34.640+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tspxe.cpp:177">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="10:19:34.640+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="commandline.cpp:229">
<![LOG[set command line: "X:\sms\bin\i386\smstftp.exe" -i 172.16.1.16 get \SMSTemp\2009.08.18.10.08.04.0003.{A97578A4-6C34-445A-9213-D6B5124EB707}.boot.var X:\sms\data\variables.dat]LOG]!><time="10:19:34.640+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="commandline.cpp:707">
<![LOG[Executing command line: "X:\sms\bin\i386\smstftp.exe" -i 172.16.1.16 get \SMSTemp\2009.08.18.10.08.04.0003.{A97578A4-6C34-445A-9213-D6B5124EB707}.boot.var X:\sms\data\variables.dat]LOG]!><time="10:19:34.640+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="commandline.cpp:805">
<![LOG[Process completed with exit code 0]LOG]!><time="10:19:37.687+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="commandline.cpp:1102">
<![LOG[succesfully removed firewall rule for Tftp]LOG]!><time="10:19:37.734+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="fwopen.cpp:146">
<![LOG[successfully downloaded pxe variable file.]LOG]!><time="10:19:37.734+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tspxe.cpp:187">
<![LOG[we are booted using PXE]LOG]!><time="10:19:37.734+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:2223">
<![LOG[we are booted using PXE and we use a generated password]LOG]!><time="10:19:37.734+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:2228">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="10:19:37.734+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsremovablemedia.cpp:321">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sms_fre\sms\framework\smscrypt\windes.cpp,185)]LOG]!><time="10:19:37.750+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="windes.cpp:185">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, wcslen(pszPassword)*sizeof(WCHAR), encryptedBuffer.getBuffer(), encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sms_fre\sms\framework\tscore\tsremovablemedia.cpp,386)]LOG]!><time="10:19:37.750+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsremovablemedia.cpp:386">
<![LOG[Verifying media password.]LOG]!><time="10:19:37.750+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:267">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="10:19:37.750+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsremovablemedia.cpp:321">
<![LOG[Found network adapter "Broadcom NetXtreme Gigabit Ethernet" with IP Address 172.18.5.128.]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmbootstraputil.cpp:434">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsremovablemedia.cpp:321">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sms_fre\sms\framework\smscrypt\windes.cpp,185)]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="windes.cpp:185">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, wcslen(pszPassword)*sizeof(WCHAR), encryptedBuffer.getBuffer(), encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sms_fre\sms\framework\tscore\tsremovablemedia.cpp,386)]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsremovablemedia.cpp:386">
<![LOG[Entering TSMediaWizardControl::GetPolicy.]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmediawizardcontrol.cpp:482">
<![LOG[Environment scope "Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}" successfully created]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="environmentscope.cpp:250">
<![LOG[Environment scope "Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}" successfully created]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="environmentscope.cpp:250">
<![LOG[setting LogMaxSize to 1000000]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:510">
<![LOG[setting LogMaxHistory to 1]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:511">
<![LOG[setting LogLevel to 0]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:512">
<![LOG[setting LogEnabled to 1]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:513">
<![LOG[setting LogDebug to 1]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:514">
<![LOG[Loading variables from the Task Sequencing Removable Media.]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:534">
<![LOG[setting _SMSMediaGuid TS environment variable]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSBootMediaPackageID TS environment variable]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSHTTPPort TS environment variable]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSHTTPSPort TS environment variable]LOG]!><time="10:19:37.828+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSIISSSLState TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSLaunchMode TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSMP TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSMPPort TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSMediaPFX TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSPublicRootKey TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSSiteCode TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSUseFirstCert TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSx64UnknownMachineGUID TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[setting _SMSTSx86UnknownMachineGUID TS environment variable]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="1" thread="1344" file="tsmediawizardcontrol.cpp:551">
<![LOG[sMPCert.size() > 0, HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,563)]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmediawizardcontrol.cpp:563">
<![LOG[No MP Certificates.]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="3" thread="1344" file="tsmediawizardcontrol.cpp:563">
<![LOG[Exiting TSMediaWizardControl::GetPolicy.]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmediawizardcontrol.cpp:1107">
<![LOG[GetPolicy(), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2058)]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmediawizardcontrol.cpp:2058">
<![LOG[RunWizardForPXE(), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2383)]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmediawizardcontrol.cpp:2383">
<![LOG[oTSMediaWizardControl.Run( sMediaRoot, true, true ), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,936)]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmbootstrap.cpp:936">
<![LOG[Execute( eExecutionEnv, sConfigPath, sTSXMLFile, uBootCount, &uExitCode ), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1105)]LOG]!><time="10:19:37.843+000" date="08-18-2009" component="TSPxe" context="" type="0" thread="1344" file="tsmbootstrap.cpp:1105">
I read "No MP Certificates", maby this link might help: http://social.technet.microsoft.com/Forums/en-US/configmgrosd/thread/0b0a5940-cf66-414a-8e93-997215667cbd
And otherwise I think of two things:
1. Is see two different ip ranges: 172.16.1.16 and 172.18.5.128 can they reach eachother?
2. Is your Network Access Account locked?
