tompsmith Posted November 7, 2014 Report post Posted November 7, 2014 Hello, I wonder if anyone can help please. I have SCCM 2012 installed in my environment. Im having issues deploying office 2013 pro sp1 via SCCM, the main issue is that Lync 2013 client does not seem to deploy to machines when the install runs. I have ran the office customisation wizard and created a custom msp file. created an application is sccm and advertised to a collection. The install occurs on users machines but Lync doesn't seem to appear in the program list? anybody come across this? Thanks Quote Share this post Link to post Share on other sites More sharing options...
ludi2014 Posted November 7, 2014 Report post Posted November 7, 2014 Try this 1) Make Lync 2013 office customization package 2) Change Config.XML file located in x86\lync.ww or x64\lync.ww and change the below line as it is mentioned:<Setting Id=”SETUP_REBOOT” Value=”never” /> This will ensure that SCCM 2012 deployment package will not allow Lync to restart and complete the deployment successfully. Note: Don’t forget to place this file on the root of your installation (deployment) folder for SCCM to read it. 3) Create SCCM deployment package and keep the command line installation parameter as “setup.exe /adminfile <Lync2013OfficeCustomizationFileName>.MSP”. kind regard sg http://www.learnmesccm.com/ https://www.linkedin...ahic/a0/842/b21 Quote Share this post Link to post Share on other sites More sharing options...
ludi2014 Posted November 7, 2014 Report post Posted November 7, 2014 Try this 1) Make Lync 2013 office customization package 2) Change Config.XML file located in x86\lync.ww or x64\lync.ww and change the below line as it is mentioned: <Setting Id=”SETUP_REBOOT” Value=”never” /> This will ensure that SCCM 2012 deployment package will not allow Lync to restart and complete the deployment successfully. Note: Don’t forget to place this file on the root of your installation (deployment) folder for SCCM to read it. 3) Create SCCM deployment package and keep the command line installation parameter as “setup.exe /adminfile <Lync2013OfficeCustomizationFileName>.MSP”. kind regard sg http://www.learnmesccm.com/ https://www.linkedin...ahic/a0/842/b21 Quote Share this post Link to post Share on other sites More sharing options...
surfincow Posted November 21, 2014 Report post Posted November 21, 2014 Dunno if your problem was resolved but if not, this may help: http://blogs.technet.com/b/odsupport/archive/2014/03/21/lync-2013-and-onedrive-for-business-are-not-installed-when-installing-office-2013-with-service-pack-1.aspx Quote Share this post Link to post Share on other sites More sharing options...
