regan
vbs script issues
I've created a script to copy a file from a file share to a directory on the PC, This runs fine when i run it independently but when i try creating a package in SCCM it either says installed when it hasn't or it fails. I've tried using cscript.exe /the name of script.vbs as well as without using that. The script is below
Option Explicit
dim path
path=CreateObject("WScript.Shell").ExpandEnvironmentStrings("C:\Program Files (x86)\Cisco Systems\VPN Client\Profiles")
dim objFSO
set objFSO=CreateObject("Scripting.FileSystemObject")
If objFSO.FileExists(path & ("\vpn.pcf")) = False Then
ObjFSO.CopyFile "\\server-fileshare\APPS\VPN new\Client Software\vpn.pcf", path & "\"
end if
