DeSchizz
SCCM 2012 R2 - Task Sequence for Built In OS Recovery Features Win 8.1 Pro
HI All,
What a great Forum, it's been a tremendous help with deploying images with SCCM on the SurfacePro 3 Tablets, than you for all your hard work and help!!!!
I've have a question that I hope some can help with. Being a new Task Sequence designer, I haven't been able to figure out how to add the Windows Recovery options to the task sequence. Currently, if I need to do a system Refresh, or a complete Re install of the OS, I have to do this via SCCM rather than through the OS. How can I setup my task sequence to add these features? Or am I barking up the wrong tree here? I've had a recent situation where a user in the field lost their WiFi device and after many minutes of trouble shooting I wanted to perform a system refresh, however when trying to do so Windows kindly tells me no. That those resources are not available.
Thank you in advance for any advice.
DeSchizz (aka Chris)
it's possible but would have to be done as part of your deploy task sequence
simply recreate the winre area in the recovery partition by copying the winre.wim file from the c:\windows\system32\Recovery folder... to accomplish this do:
set recovery partition letter in diskpart (for example Q)
Robocopy.exe C:\Windows\System32\Recovery\ Q:\Recovery\WindowsRE\ Winre.wim /copyall /dcopy:t
reagentc /setreimage /path Q:\Recovery\WindowsRE
reagentc /enable
go back in disk part and remove the drive letter set before
then confirm it works with:
reagentc /info
in addition to the above you'll need to store your custom.wim file (the osd image) handy
