mbandala
SCnotification.exe crashes and makes machine unusable
Hello all,
I'm running into an issue with our VM servers that have the SCCM 2012 R2 client installed. The symptoms are that some servers become unstable, and cannot be RDP'd to. When logging on to those servers through a VM console, I see that the SCNotification.exe has stopped working. This message does not go away.
Server becomes responsive again only when the SCCM client is uninstalled.
MS support has only been pointing us to reinstall .NET due to a corrupt installation. But this has happened with multiple machines. I do not think a corrupt install has occurred on every machine.
If anyone has any ideas, it would be greatly appreciated!
Event logs show Event 1026 and Event 1000 with .NET runtime application error with SCNotification.exe
Event 1026 .NET runtime
Application: SCNotification.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Net.Sockets.SocketException
Stack:
at System.Net.Sockets.Socket.DoBind(System.Net.EndPoint, System.Net.SocketAddress)
at System.Net.Sockets.Socket.Bind(System.Net.EndPoint)
at System.Net.Sockets.TcpListener.Start(Int32)
at System.Runtime.Remoting.Channels.ExclusiveTcpListener.Start(Boolean)
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel.StartListening(System.Object)
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel.SetupChannel()
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel..ctor(System.Collections.IDictionary, System.Runtime.Remoting.Channels.IServerChannelSinkProvider, System.Runtime.Remoting.Channels.IAuthorizeRemotingConnection)
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel..ctor(System.Collections.IDictionary, System.Runtime.Remoting.Channels.IServerChannelSinkProvider)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.RegisterChannel(ChannelType, Boolean)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(System.String[])
at Microsoft.SoftwareCenter.Client.Notification.SingleInstanceApplication.Main(System.String[])
Event 1000. Appllication Error
Faulting application name: SCNotification.exe, version: 5.0.7958.1000, time stamp: 0x5230d2bb
Faulting module name: KERNELBASE.dll, version: 6.3.9600.16656, time stamp: 0x531812f4
Exception code: 0xe0434352
Fault offset: 0x00012c1a
Faulting process id: 0x5ad4
Faulting application start time: 0x01cffd055d9fdeb2
Faulting application path: C:\Windows\CCM\SCNotification.exe
Faulting module path: C:\Windows\SYSTEM32\KERNELBASE.dll
Report Id: 9b5ab896-68f8-11e4-80c9-005056a21742
Faulting package full name:
Faulting package-relative application ID:
