FromTheUnderground Posted November 21, 2014 Report post Posted November 21, 2014 Hello all. I am running into multicast issues and looking for some help. Current system: SCCM 2012 R2 Cumulative Update 3 (5.0.7958.1401) with 1 site server, 1 db server, and 1 distribution point. I have a task sequence to push out an image via multicast but on the client computer I keep getting error number 80070002. The DP is set to enable multicast, all the contact within the task sequence is located on the DP and all packages are set to "allow this package to be transferred via multicast." I read a few places that turning off multicast support on the DP for an hour then turning it back on would correct the issue. This is a copy of the log file after doing so. Notice the Error finding namespace entry in the log. Any help and suggestions would be greatly appreciated. Thank you. Josh Multicast error file: Setting WDS IpAddressSource McsExec 11/21/2014 1:38:51 PM 5088 (0x13E0) Running: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:38:51 PM 5088 (0x13E0) Waiting for completion of: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:38:51 PM 5088 (0x13E0) Run completed for: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:38:52 PM 5088 (0x13E0) Running: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:38:52 PM 5088 (0x13E0) Waiting for completion of: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:38:52 PM 5088 (0x13E0) Run completed for: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) Succesfully Configured WDS McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) Error finding namespace McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) Checking MCS Certificate McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) MCSEncryptionCert Created. Length 980. McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) ========== HealthCheck ffffffff-ffff-ffff-ffff-ffffffffffff McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) Error finding namespace: 0xc1100113 McsExec 11/21/2014 1:38:53 PM 5088 (0x13E0) Setting WDS IpAddressSource McsExec 11/21/2014 1:38:55 PM 2468 (0x09A4) Running: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:38:55 PM 2468 (0x09A4) Waiting for completion of: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:38:55 PM 2468 (0x09A4) Run completed for: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:38:56 PM 2468 (0x09A4) Running: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:38:56 PM 2468 (0x09A4) Waiting for completion of: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:38:56 PM 2468 (0x09A4) Run completed for: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:38:57 PM 2468 (0x09A4) Succesfully Configured WDS McsExec 11/21/2014 1:38:57 PM 2468 (0x09A4) Setting WDS IpAddressSource McsExec 11/21/2014 1:43:36 PM 4924 (0x133C) Running: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:43:36 PM 4924 (0x133C) Waiting for completion of: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:43:36 PM 4924 (0x133C) Run completed for: WDSUTIL.exe /Set-TransportServer /ObtainIPv4From:Range /Start:239.0.0.1 /End:239.0.0.254 McsExec 11/21/2014 1:43:37 PM 4924 (0x133C) Running: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:43:37 PM 4924 (0x133C) Waiting for completion of: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:43:37 PM 4924 (0x133C) Run completed for: WDSUTIL.exe /Set-TransportServer /StartPort:64001 /EndPort:65000 McsExec 11/21/2014 1:43:38 PM 4924 (0x133C) Succesfully Configured WDS McsExec 11/21/2014 1:43:38 PM 4924 (0x133C) ========== HealthCheck ffffffff-ffff-ffff-ffff-ffffffffffff McsExec 11/21/2014 1:43:53 PM 4244 (0x1094) Error finding namespace: 0xc1100113 McsExec 11/21/2014 1:43:53 PM 4244 (0x1094) Error finding namespace McsExec 11/21/2014 1:48:53 PM 3328 (0x0D00) ========== HealthCheck ffffffff-ffff-ffff-ffff-ffffffffffff McsExec 11/21/2014 1:48:53 PM 312 (0x0138) Error finding namespace: 0xc1100113 McsExec 11/21/2014 1:48:53 PM 312 (0x0138) ========== HashAndSignBuffer McsExec 11/21/2014 1:52:19 PM 312 (0x0138) ========== OpenSession McsExec 11/21/2014 1:52:19 PM 312 (0x0138) Error finding namespace McsExec 11/21/2014 1:52:19 PM 312 (0x0138) ========== OpenSession -- exit code: 0xc1100113 McsExec 11/21/2014 1:52:19 PM 312 (0x0138) ========== HashAndSignBuffer McsExec 11/21/2014 1:52:19 PM 312 (0x0138) ========== OpenSession McsExec 11/21/2014 1:52:20 PM 312 (0x0138) Error finding namespace McsExec 11/21/2014 1:52:20 PM 312 (0x0138) ========== OpenSession -- exit code: 0xc1100113 McsExec 11/21/2014 1:52:20 PM 312 (0x0138) ========== HealthCheck ffffffff-ffff-ffff-ffff-ffffffffffff McsExec 11/21/2014 1:53:53 PM 312 (0x0138) Error finding namespace: 0xc1100113 McsExec 11/21/2014 1:53:53 PM 312 (0x0138) Quote Share this post Link to post Share on other sites More sharing options...
