I'm trying to load a machine and it seems like it installs fine then it reboots and it appears it didn't write the boot partition. I receive the following error “UNMOUNTABLE_BOOT_VOLUME†I pulled the logs and they are as follows:
Failed to save environment to (80070057)
Failed to save the current environment block. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
The parameter is incorrect. (Error:80070057; Source: Windows)
Failed to persis execution state. Error 0x(80070057)
Failed to save execution state and environment to local hard disk.
All,
Any help would be greatly appreciated.
