aazani
Auto create computername
Hi Guys,
I'm trying my best to find a solution for this but I haven't found one yet (or i'm just not looking hard enough). My question is simple, i hope the solution is simple to haha
The complete TS is automated, it activates windows and so on except for the computer name. We want to have it like this
DEPT-01 and next will be DEPT-02 and so on. DEPT is just a sort code for the departement, for example finance departement would be something like FIN-01 and next will be FIN-02 and so on.
How can i automate this? Can someone help me out?
9 answers to this question
Hi, depending on which tool you are using, this may be an example which will help you get further:
http://www.deploymentresearch.com/Research/tabid/62/EntryId/103/Generate-computer-names-in-MDT-2012-2013-based-on-prefix-and-a-sequence-number.aspx
It was already possible to store computernames in a database with MDT, just as it is with SCCM. But this blogpost explains how to achieve hostnames that are automatically followed-up by the previous/last given hostname.
Cheers!
also, take a look at the CM12 BitLocker Frontend HTA, it has way many more things than you need in the task sequence and associated scripts, however it also deals with auto computer naming and it might be worth your while taking a look at it
CM12 in a Lab - The CM12 BitLocker FrontEnd HTA
I'm sorry for the late reply was very busy with the implementation from test to production. I managed to figure this out. I have this powershell script that sets the OSDComputerName, but only for new computers. The others I just migrate and preserve the name. Sometimes we use the easy way if we do it only for 1 or 2 computers, by just deploying it to unknown computers as described by you.
