Deploying a .cmd script, not working
I've deployed a .cmd file out that contains a WMI script to uninstall all instances of an application called "VirtViewer". The script looks like this:
taskkill /F /IM remote-viewer.exe /T
wmic product where "name like 'VirtViewer%%'" call uninstall /nointeractive
exit /B %EXIT_CODE%
Previously, I had used MSI product codes for the uninstall, and got the same result. My original problem, is that there are currently 9 different versions of this app out there, so i am ripping them all out and replacing with 1 version. Installing over an old version does not overwrite the older one, it instead installs a new instance.
Reading through the execmgr.log on the client, everything looks as it should. I have attached the execmgr.log to the post.
The end result, is that nothing happens. I had originally set the program to run as hidden, but then changed it to normal but still do not see it run. The application is right where i left it, untouched. If i run the script locally it works fine, but not when deployed. Am i missing something??
execmgr.log
I just tried using powershell to accomplish the same task, and got the same result. Script ran fine, but nothing resulted. 0 errors in the execmgr.log on the client.
Program options:
Command Line: Powershell.exe -executionpolicy Bypass -file .\VirtUninstall.ps1
the powershell script looks like this:
$app = Get-WmiObject -Class Win32_Product | Where-Object {$_.Name -match "VirtViewer*"}
$app.Uninstall()
exit /B
Again, the script runs great when launched locally, but not wehen deployed
What if you try:
%windir%\Sysnative\wmic product
exit /B %EXIT_CODE%
I ended up getting this to work by changing the program environment variables. It was originally trying to uninstall from SYSTEM and was not finding anything. I changed this option to only run when a user was logged in, and run with the users rights and it worked perfectly. This particular program installs on a per user basis, something i was not aware of at the starts
