d0zer Posted September 2, 2009 Report post Posted September 2, 2009 It´s me again. Now i have just the problem with the wsus. we have another wsus in our environment, so i don´t want to install the wsus on the sccm. can i proceed without wsus? Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted September 2, 2009 Report post Posted September 2, 2009 You can continue without installing WSUS. WSUS is only needed with setting up a Software Update Point. Quote Share this post Link to post Share on other sites More sharing options...
d0zer Posted September 3, 2009 Report post Posted September 3, 2009 Good morning i´ve completed the setting up of sccm. now i´m on this tutorial: http://www.windows-noob.com/forums/index.php?/topic/489-how-can-i-configure-sccm-2007-sp1-in-windows-server-2008/ now i have to add a new boundary. my site code has to be the name of my domain, am i right? how can i add my domain(site) if the AD is on own Domain Controller? in the sccm i just see my site, that i added at the setup of sccm. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted September 3, 2009 Report post Posted September 3, 2009 I really would like to help, but I got no clue what you mean here... Quote Share this post Link to post Share on other sites More sharing options...
d0zer Posted September 4, 2009 Report post Posted September 4, 2009 i just finished setting up the sccm. i can see all the computers in my collections, that are in my domain. now i want to install the Configuration Manager client on a windows 7 pc. the pc ist called "pcvaio". i´ve found this pcvaio unter collections/all system. right click on this pc and choose "install client". than i checked "include only clients in this sites boundaries". clock ok and than finish. but on the pcvaio there is no Configuration Manager in the control panel. what have i to do, to install the Configuration Manager client on pcvaio. have i to create a software package that includes the Configuration Manager client or should the installation work how i figured above? Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted September 4, 2009 Report post Posted September 4, 2009 are you sure the client isn't installed, the Windows 7 control panel is different to say the least, in the windows 7 control panel search for config and see does the configuration manager client show up if not, check your firewall settings on the client Quote Share this post Link to post Share on other sites More sharing options...
d0zer Posted September 4, 2009 Report post Posted September 4, 2009 there is nothing in the control panel. firewall is also right. i tried to install the client manually, in the process explorer i also see "ccmsetup.exe" but nothing happens. do i need sccm 2007 SP2 (Beta) to install the Client on a Windows 7 ? The SP2 Beta supports officially Windows 7. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted September 4, 2009 Report post Posted September 4, 2009 On 9/4/2009 at 10:51 AM, d0zer said: do i need sccm 2007 SP2 (Beta) to install the Client on a Windows 7 ? The SP2 Beta supports officially Windows 7. Well... It is true that Windows 7 is officially supported since SP2 (which is already in RC), but you should be able to deploy a client... At least it worked with me. But to be sure if it is working or not I would try on a different OS or install SP2. Quote Share this post Link to post Share on other sites More sharing options...
sccm_freak Posted March 9, 2010 Report post Posted March 9, 2010 i want to clarify something please lets say i have AD ,DHCP and DNS on one server SCCM 2007 with WSUS on another ( called SCCM) finally SQL separetly ( called SQL 2005 ) in the prerequisite check i need to put for the primary site and SDK the name SQL 2005 and for the MP SCCM ? please confirm thanks Quote Share this post Link to post Share on other sites More sharing options...
sccm_freak Posted March 9, 2010 Report post Posted March 9, 2010 any help please thanks Quote Share this post Link to post Share on other sites More sharing options...
