Fresh exchange 2013 installation on Server 2012 R2
Install went smooth, and kept everything on default.
I am trying to the ECP page, i log in successfully, but it only shows me limited OWA/Menu, doesn't look like the full ECP at all.
I tried to change the ECP IIS settings to ask for credentials and even when i log in with the username exchanged was installed with - same problem (it's 1 user in total i just tried to manually log in)
Hello
see PS http://i.imgur.com/SCPFwfy.png
i use https://localhost/ecp
tried to remove ssl requirement and use http only, tried different ports (81 / 444) just in case etc - same problem...
What am I missing here?
