checksergio Posted January 26, 2015 Report post Posted January 26, 2015 Some curious behavior I just noticed, our machines that have had the client pushed to them automatically upon discovery- do not install that client again once re-imaged. Manual push still works on tested machines so that ruled out admin account authentication, IP ranges etc. Someone suggested deleting the old entry from SCCM, and sure enough AD discovery brought the device back again the next day, but still no client. I am 100% sure the solution lies in tuning Heartbeat discovery and the clear flag maintenance task. I have mine set up to run at weekly intervals and the CF task every Saturday, but yet here is Monday and the agent still hasn't deployed yet (but yet that "weekly" interval for Heartbeat discovery is vague so who knows what day it runs on- what log would this be by the way). Any suggestions? Thanks, Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted January 26, 2015 Report post Posted January 26, 2015 If you're not using ConfigMgr for the OS deployment, then yes the solution is in tuning the combination of the Heartbeat Discovery and the Clear Install Flag. As long as the console still shows client YES, then the automatic client push will not be performed. 1 Quote Share this post Link to post Share on other sites More sharing options...
checksergio Posted January 26, 2015 Report post Posted January 26, 2015 On 1/26/2015 at 7:16 PM, Peter van der Woude said: If you're not using ConfigMgr for the OS deployment, then yes the solution is in tuning the combination of the Heartbeat Discovery and the Clear Install Flag. As long as the console still shows client YES, then the automatic client push will not be performed. Would you happen to know how I can pinpoint the exact time the HB discovery is done? as in day, time ....There must be some kind of log somewhere. Without knowing the exact time, kind of hard to tune the two to work with each other Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted January 27, 2015 Report post Posted January 27, 2015 You can look in the properties of the device and look at the Agent Time property. You need the Agent Time that's on the same position as Heartbeat Discovery with Agent Name. Quote Share this post Link to post Share on other sites More sharing options...
