hei,
Never had that error. Have had (0x80070032) but that was for a partitioning error in my target client.
VMs are one of the easiest clients to capture...if everything goes right! ;-)
What is the sequence of events that you are doing? What are your logs telling you? Can you give some more contextual information?
Thanks for you reply,
opps, sorry I miss typed the error message it is 32 and not 37.
I get the error message as soon as I try to capture, right after selecting the relevant task sequence
I did think it was something to do with partitioning.
I removed all partitions apart from the OS one, and made it the first partition.
I then created a NTFS partition.
Still cant capture anything, any ideas.
Cheers
