Tox
Installed Software Problem
Hi There,
I'm using SCCM for a quite long time to deploy Windows Updates in my Windows Infrastructure. Now I need to start monitoring the software installed on the computers and I activated this option on my SCCM (and did the changes on the client settings). The problem now is that I can only see some of the software installed. Not every software appear on my lists. For example, I know that almost every workstation uses Lotus Notes Client, and if I do a report for Lotus Notes it only appears 4 installations (it should be hundreds). Another example is Microsoft Office 2010, If I do a report for this software, it only shows a few machines with the software installed (and it should be hundreds).
Can someone give me a tip to solve this problem?
Thanks in advance,
