Chris_J
Re-imaging issue
Hi All, I made a task sequence to capture user state, then Apply Operating System etc. I disabled the steps to Partition and Format the disk, and have OSDPreserveDriveLetter = False set. The OS then installed onto D:. Is the issue that I have OSDPreserveDriveLetter set? Also this build had BitLocker continually asking for the Recovery Key on boot up.
0 answers to this question
