RobJanssen86
Offline deployment USB drive letter assignment
Currently I am running in the following issue:
My task sequence creates 2 partitions:
Part 1 = 100 GB called OS (with variabele OSDISK)
Part 2 = 100% remaining size called DATA
My OS is deploying it's image to OSDISK, so always partition 1. Which is correct.
Because I am deploying via Task Sequence media, my USB stick gets drive letter D and the SCCM task sequence is creating an E: partition (part 2) for me, this is not what I want!!
During the task sequence I am creating folders on the D drive, which results in getting folders on my USB stick :(
How can I solve this?
