Steve G. Posted March 25, 2015 Report post Posted March 25, 2015 Here's what the scenario: Potentially hundreds of computers to replace. A couple dozen PC technicians. One (1) SCCM administrator. Management insists that data be backed up prior to OS deployment in the event of catastrophic failure during occurring during said deployment. In Config Manager 2007, this was simple enough to handle. We had a handy-dandy task sequence that mapped a drive to a network share, and then ran the backup to that location, with a little variable that named the file after the source computer. If anyone ever needed data restored, they could just fire up Windows Easy Transfer and look for that file. Sure, we did hard-linking and in-place backups and restores, but it was definitely helpful to simply have the data sitting on mass storage and accessible to people who weren't SCCM admins. In Config Manager 2012, however, a USMT task sequence fails with an error that indicates it doesn't allow backups to mapped drives. Now, everything I've read about state migration points seems to rely creating manual one-to-one relationships between the source and destination computers, which doesn't seem practical with large scale deployments. It also seems to necessitate using SCCM to perform all restores, so a PC technician can't just snag the backup and restore it. Has anyone had to face such a scenario? Are there any good guides for USMT to facilitate an en-masse PC-replacement? Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted March 25, 2015 Report post Posted March 25, 2015 the task sequence below backs up data just fine to mapped shares CM12 in a Lab - The CM12 UEFI BitLocker FrontEnd HTA - Part 2. Installation CM12 in a Lab - The CM12 UEFI BitLocker Frontend HTA - Part 1. The features. Quote Share this post Link to post Share on other sites More sharing options...
Steve G. Posted March 27, 2015 Report post Posted March 27, 2015 Thanks for the response. It's interesting that there's no error capturing a user state directly to network storage, since both USMT 4 and 5 have not been able to do so in our environment. When we opened a ticket with MS, they said this was intended behavior. Quote Share this post Link to post Share on other sites More sharing options...
Steve G. Posted March 27, 2015 Report post Posted March 27, 2015 I attempted to import the task sequence, however even with ignoring the dependency, the import failed with an error: Error: Imported Task Sequence Package (1): Ignore Dependency CM12 UEFI BitLocker HTA Not found instance of __ExtendedStatus{ Description = "Failed to load class properties and qualifiers for class BDD_UsePackage in task sequence."; Operation = "ExecMethod"; ParameterInfo = "SMS_TaskSequence"; ProviderName = "WinMgmt"; StatusCode = 2147749890; Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted March 29, 2015 Report post Posted March 29, 2015 do you have mdt 2013 integrated ? Quote Share this post Link to post Share on other sites More sharing options...
Steve G. Posted March 31, 2015 Report post Posted March 31, 2015 I don't have MDT, MBAM, or the Maik Kosters web service. I can go install all the stuff, but can you help me appreciate how MDT will address what seems to be a USMT limitation? The TS is pretty simple. It doesn't boot to any kind of PE. One task creates a TS variable OSDStateStorePath, and has a value that points to the mapped drive. The Capture User State task that follows it is perfectly vanilla. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted April 1, 2015 Report post Posted April 1, 2015 from your error message "Failed to load class properties and qualifiers for class BDD_UsePackage in task sequence.": that's complaining about the lack of MDT Integration. This integration gives a lot more abilities that you think and it all collectively helps the task sequence mentioned above into a reality, (via the scripts etc), try it and see. Quote Share this post Link to post Share on other sites More sharing options...
