Felix Cruz III
Task Sequence for Kontron PITx-e38 device. Need assistance
I have a Kontron PITx-e38 device that is running Windows Embedded Standard 7 write protected on a SD Card.
The device's BIOS is Phoenix Secure Core Technology v.pITXE38.314.TXE1060.PVLV1018.B16 x64
I ran diskpart /s clean.txt
clean.txt contains:
select disk 0
clean
create partition primary
select partition 1
format fs=ntfs quick
assign letter=c
active
exit
In TS "Apply Operating System Image" Destination Specific disk and partition Disk: 0 Partition: 1
I encounter:
The task sequence execution engine failed executing the action (Windows Embedded PICO 7 SP1 x86) in the group (PICO) with the error code 2147943568
Action output: ... t:0,1 /runfromnet:False
Found run from net option: 0
Not a data image
ApplyOSRetry:
TSLaunchMode: UFD
OSDUseAlreadyDeployedImage: FALSE
Interface type not USB: 'SCSI'
Skipping non-local logical drive: C:
Skipping non-local logical drive: D:Skipping non-local logical drive: E:
Skipping non-local logical drive: X:
CDisk::FixedDiskToLogicalDrive( target.Disk, target.Partition, volume), HRESULT=80070490 (e:\nts_sccm_release\sms\client\osdeployment\applyos\installcommon.cpp,639)
ResolveTarget( g_Target, g_InstallType == InstallType_DataImage, targetVolume ), HRESULT=80070490 (e:\nts_sccm_release\sms\client\osdeployment\applyos\applyos.cpp,483)
TS::Utility::CDisk::FixedDiskToLogicalDrive failed; 0x80070490
Disk 0, partition 1 does not existor is not a valid volume
The requested target could not be resolved to a valid volume on this computer. Check your task sequence to ensure this drive is correct and that it is being created
he parameter is incorrect. (Error: 80070057; Source: Windows). The operating system reported error 2147943568: Element not found.
Note: I can apply this image via dsim / imagex command line but trying to standardize clients imaging process to use SCCM.
0 answers to this question
