JTPort
DP Issue
Been having some issues transferring some packages, with them coming back as failed. Have checked the component status and the below is in the despooler log
Despooler failed to merge delta to the compressed package. The operating system reported error 3: The system cannot find the path specified.
Possible cause: The destination drive is full.
Solution: Make more space available on that drive. Despooler will attempt to merge the delta again during its next retry interval
I've checked the destination and both have plenty of space. I then checked the SMS_Package transfer status and the errors below occured
Package Transfer Manager failed to update the package, Version 1 on distribution point. Review PkgXferMgr.log for more information about this failure.
Possible cause: Site server does not have sufficient rights to the source directory.
Solution: Verify that the site server computer account has at least Read access to the directory you specify as the source directory.
Possible cause: There is not enough disk space available on the distribution point.
Solution: Verify that there is enough free disk space available on the distribution point.
the site server has admin rights on the DP and there is free space on the drives.
In the PkgXferMgr.log I get the following errors:
CContentDefinition::TotalFileSizes failed; 0x80070003
CSendFileAction::SendFiles failed; 0x80070003
Sending failed. Failure count = 40, Restart time = 07/04/2015 15:06:20 GMT Daylight Time
I've tried removing the application from the DP, and resending. I've tried reinstalling the DP. Has anyone got any ideas?
another person solved this issue by the following:
Remove distribution point role;
Remove WDS role;
remove all folders of distribution folders and WDS. (SMSPKGE$, SMSSIG$, SCCMContentLib, RemoteInstall);
Reboot Server;
reinstall all roles;
Redistribute packages.
http://www.windows-noob.com/forums/index.php?/topic/4856-boot-images-failing-to-update/
