I've got an odd problem with System Center 2012 Data Protection Manager. When trying to protect a machine if you select the C:\ drive the following error appears;
I have tried this on the following OS's;
2003 x86, 2008, 2008 R2, 2012 R2, Windows 7 x64
This also occurs on the DPM server itself, it cannot access its own C:\ to backup
Other drives are fine, as is system state and SQL backups (which are stored on C:\)
I have tried;
Removing Antivirus
Restarting both DPM server and client machine
Reinstalling DPM agent and installing agent on a machine which has never been managed by DPM (account used to install is domain admin). Every time the agent comes back as OK
Removed all GPO's from the DPM server
Used psexec to run a cmd.exe as system to check file permissions
Installed all updates to windows and DPM, running v 4.2.1297.0
Its installed on a Windows 2012 R2 Server with SQL 2012. There is nothing else installed on the machine and has been built from scratch for this purpose.
No amount of googling has brought me any joy... I do hope someone has seen this before and can help me out!!
Hey Guys
I have tried;
Have tried these technet articles;
https://technet.microsoft.com/en-us/library/hh858521.aspx?f=255&MSPPError=-2147217396
https://technet.microsoft.com/en-us/library/cc161655.aspx?f=255&MSPPError=-2147217396
Ben
