leprejohn Posted May 14, 2015 Report post Posted May 14, 2015 Do you have an ip-helper on your vlan, assuming you may be using a layer 3 and not layer 2. Hi Chris I don't have an ip-helper on my vlan this is all set up in virtual box with DCHP disabled within virtual box Quote Share this post Link to post Share on other sites More sharing options...
Garrett804 Posted May 14, 2015 Report post Posted May 14, 2015 ok so I think we need some more information on your environment. 1. You say you have DHCP disabled so where exactly are you pulling IP's from then to do PXE? 2. Do you run WDS on the same subnet as this machine you are testing with? (this wouldn't require ip-helpers) Quote Share this post Link to post Share on other sites More sharing options...
