yor
PullDP problem
I have one primary site server and 4 distribution points all running Windows Server 2012 R2 and System Center 2012 R2 version 5.00.7958.1000. In the past I have been able to distribute applications I have created to all distribution points without issue. Recently I have been getting failures from 3 of my DP's. However, one of the DP's, I am still able to distribute to. The Pulldp.log file from one of the problematic DP's always shows this
Failed to find space for 104857832 bytes. PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
CFileLibrary::FindAvailableLibraryPath failed; 0x8007050f PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
CFileLibrary::AddFile failed; 0x8007050f PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
CPullDPPkgContJob::ExecuteJob() failed for package HEB0006C, version 1 PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
State at failure: Downloaded PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
Content job Content_4b211bce-21bb-414d-81a6-30a9fc8893f4.1 has failed for package HEB0006C, version 1 PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
Package job has failed for package HEB0006C, version 1 PullDP 4/21/2015 9:34:49 AM 3360 (0x0D20)
there is plenty of space on the drive (26.6 gb free) All of my DP's are sized exactly the same. 3 of them are failing with the same thing in the pulldp.log file as above and the other is succeeding. All of my permissions are exactly the same and as I have already stated this is something that has been working. The only things that have changed are Windows updates. They all have the same updates applied to them. I have attached the full pulldp.log file from the dp I am able to successfully distribute to and one I have been failing to do so.
PullDP_success.log
PullDP_failed.log
