SCCMNewbie1
SCCM 2012 R2 Adding second domain without SChema Extension same forest
Halo Everyone,
Hope you guys had a great weekend..........!!!!
I have a question from the forum members ?
Start with the Environment Overview:
Single Forest environment , two domains
Domain A : New Domain Created with SCCM 2012 R2 installed
Domain B: Existing Domain with 500 Clients approx
Now,
Created a totally new SCCM 2012 R2 environment in a new domain Domain A.
OSD , App Deployment , S/W Patching working like a charm. :)
But there is another requirement by company :
Company's requirement is to Add Domain B to the SCCM 2012 R2 and manage it the same way as primary Domain A (i.e OSD, App Deployment, S/W Patching)
But, they are hesitant for the making any changes in the second Domain (i.e AD Schema extension and System Management Container creation)
Configuration done So far :
- Added the Domain B to SCCM 2012 R2 , ran Forest Discovery successfully.
- Have Discovered all the Client Machines in Domain B
- Configured the Client settings for pushing the Client Agent to Domain B machines
(Note that the SCCM Client Push Account has domain Admin rights on Domain B)
But Unable to push Client on Domain B Machines
Tried to test on 5-10 machines, but apparantely it is failing to create the ccmsetup folder
due to privillege issue ( I Guess )
Good thing
Both MP (Domain A ) and DC (Domain B) can resolve each others DNS successfuly.
As it is a same Forest, I assume don't have to set any trust relationship.
So, I want to manage Domain B ( Old Domain Same Forest ) same way I am able to manage Domain A ( New Domain, Same Forest) without making any changes or extending the SCHEMA on Domain B
Also, Please suggest
How can I See the second Domain in the Task Sequence....
While Creating a OSD Task Sequence and Adding the Deployed Machine to any of the Domain ( At the Moment, can see only new Domain )
Please Help.....!!!!!!!
Have been struggling with this issue for some days now :(
Any suggestion would much appreciated...
SCCM NewBie
3 answers to this question
Since the forest has already gotten Schema extension there is nothing more to do. You other domain has everything it needs.
Why can’t you push to domain B? What error are you getting?
Domain A&B already have a full trust because they are within the same forest.
Thank you for the reply
Here is the Error Log:
Execute query exec [sp_CP_GetNewPushMachines] N’PO1′ SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Execute query exec [sp_CP_SetPushRequestMachineStatus] 2097152814, 1 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Execute query exec [sp_CP_GetPushRequestMachine] 2097152814 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Successfully retrieved information for machine TestClient from DB SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Execute query exec [sp_CP_GetPushRequestMachineIP] 2097152814 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Execute query exec [sp_CP_GetPushRequestMachineResource] 2097152814 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Execute query exec [sp_CP_GetPushMachineName] 2097152814 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Received request: “2097152814” for machine name: “TestClient” on queue: “Incoming”. SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
Stored request “2097152814”, machine name “TestClient”, in queue “Processing”. SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:18 AM 5024 (0x13A0)
—– Started a new CCR processing thread. Thread ID is 0x750. There are now 1 processing threads SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 5024 (0x13A0)
Submitted request successfully SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 5024 (0x13A0)
======>Begin Processing request: “2097152814”, machine name: “TestClient” SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 1872 (0x0750)
Execute query exec [sp_IsMPAvailable] N’PO1′ SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 1872 (0x0750)
—> Trying the ‘best-shot’ account which worked for previous CCRs (index = 0x1) SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 1872 (0x0750)
—> Attempting to connect to administrative share ‘\\TestClient\admin$‘ using account ‘Domain\svcDomJoin’ SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 1872 (0x0750)
Getting a new request from queue “Incoming” after 100 millisecond delay. SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 5024 (0x13A0)
Waiting for change in directory “C:\Program Files\Microsoft Configuration Manager\inboxes\ccr.box” for queue “Incoming”, (30 minute backup timeout). SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:20 AM 5024 (0x13A0)
—> The ‘best-shot’ account has now succeeded 1 times and failed 0 times. SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> Connected to administrative share on machine TestClient using account ‘Domain\svcDomJoin’ SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> Attempting to make IPC connection to share <\\TestClient\IPC$> SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> Searching for SMSClientInstall.* under ‘\\TestClient\admin$\‘ SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> System OS version string “6.1.7601” converted to 6.10 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> Mobile client on the target machine has the same version, and ‘forced’ flag is not turned on. Not processing this CCR SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> Deleting SMS Client Install Lock File ‘\\TestClient\admin$\SMSClientInstall.PO1‘ SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
Execute query exec [sp_CP_SetLastErrorCode] 2097152814, 120 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
—> Skipped request “2097152814”, machine name “TestClient”. SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
Deleted request “2097152814”, machine name “TestClient” SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
Execute query exec [sp_CP_SetPushRequestMachineStatus] 2097152814, 3 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
Execute query exec [sp_CP_SetLatest] 2097152814, N’04/27/2015 00:30:21′, 5 SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
<======End request: “2097152814”, machine name: “TestClient”. SMS_CLIENT_CONFIG_MANAGER 27/04/2015 10:30:21 AM 1872 (0x0750)
Config Manager applet is in th econtrol Panel.
But Software Center not installed.
Client Installation is interrupted in the middle somewhere.....
~Thanks
