SCCM Console Builder Custom Property Class
I was wondering if anyone here has used the Console Builder to add things into SCCM?
I followed the tutorial here http://idanve.blogspot.com/2015/03/add-custom-column-to-sccm-console-using.html
but I'm wondering if its possible to have a custom registry entry in a column. So here is where I'm getting at.
I have a reg key that gets placed during OSD that tells SCCM which image it has.
I can use Hardware Inventory to collect this Reg Key Value. I can run a query that tells me who has what image.
I would like to put this value into a column using the console builder if possible.
Following the tutorial I was not able to find this custom field. Does anybody have any ideas?
I think it has something to do with a property display item and/or Class Property? Is there any way to create a custom one?
I'm sure its an odd request but I'm bored at work so this will kill some time.
My problem is I can't seem to find it, Here is the query that lets me know what image is on the machines.
I tried looking under SMS_G_SYSTEM for Current Version but its not listed. Thanks
select SMS_G_System_CurrentVersion.Version,
SMS_R_System.Name from SMS_R_System inner join
SMS_G_System_CurrentVersion on
SMS_G_System_CurrentVersion.ResourceID =
SMS_R_System.ResourceId inner join
SMS_G_System_CurrentVersion64 on
SMS_G_System_CurrentVersion64.ResourceID =
SMS_R_System.ResourceId where
SMS_G_System_CurrentVersion.Version = "IMAGE1"
or SMS_G_System_CurrentVersion64.Version = "IMAGE1" order by
SMS_R_System.Name
