cool123 Posted June 22, 2015 Report post Posted June 22, 2015 installation of oracle 10g using sccm2012 pls explain or any video Quote Share this post Link to post Share on other sites More sharing options...
0 Ath3na Posted June 22, 2015 Report post Posted June 22, 2015 I've just done 11g recently, maybe 10 is similar. I used the Oracle Universal Installer to create a response file for the silent installation. then deployed it in ConfigMgr like you would any other application. The command line I used after some reading and searching was: "%~dp0setup.exe" -silent -nowelcome -noconfig -waitforcompletion -nowait -responseFile "%~dp0client.rsp" -nowait prevents the installer from presenting an ok prompt at the end and -waitforcompletion keeps the first window open while the universal installer does it's stuff. In the end it went out smoothly and was fairly straight forward. The name of the response file I used was client.rsp Quote Share this post Link to post Share on other sites More sharing options...
